I've got a built '65 289. I'm using the original distributor which has been upgraded to electronic ignition with an Ignitor II. Base timing is 16 degrees. Disti is adding another 22 max. I'm trying to dial in the vacuum advance and when I turn the vacuum adjustment 3 turns from the lowest amount of spring resistance (most advance). The car starts and seems to run fine. If, however, I reduce the resistance even more or turn it all the way to the lightest setting, the car will not start. I have the vacuum advance hooked up to the timed port on the carb. My main question is, I don't understand why the vacuum advance has any impact on the car's ability to start or idle?
In case it matters the motor makes about 13 inches of vacuum at idle. Any help would be appreciated.
