IT RUNS...finally!
woodyy24
290
illinois
runs good again, sorry about no buildup pics, i left the camera at home.
ill have a small clip of it for you guys, hopefully tomorrow.
its tomorrow,
http://media.putfile.com/blower
woodyy24 said:
mr, gasket street scoop 2 and cutting a hole to fit, split some vacuumm line and run it around the cut part for a clean look and adding some hood pins or locks. probably pins.
Sweet! You got any pics of the part you intend to use? ...And please don't cut your stock hood... find another one and cut that one up.
Daggar said:
That's gonna look badass...
How does she run? Is it all that you expected?
runs smooth, lots of torque.:nice:
it doesnt have as much power as the first time i had it running, but thats because i have the base timing set at 6 degrees as before it was at 10.
i have some 100 octane it it right now so im going to to up it by 2 degree incriments and see what happens.
the best way to describe it is like running a 100 shot if nitrous all the time.:p its fun, i get lots of stares and pointing fingers.
edit: it changed my exhaust tone quite a bit too
Get an AFR meter bro...
Start weening that thing off 100+ and get it back down to pump gas. My guess is that it was running too lean before. You should be able to get away with 10* base timing on pump gas without too much drama.
Do you have a way to control the timing advance through the RPM range?
i need to, that and a boost guage. no on the timing control, got any recomendations?
id rather not do it by boost but by rpm since it only has a max of 7.5 psi with the pulley thats on it right now.
