I installed a UPR Plenum and BBK TB.
I had a VERY high idle after. I found that the culprit was the throttle plate was not closed fully. I closed it and it helped. I also did the copper cap mod and got a pretty steady idle. But it still idles at 1200 and I get code P0507. I can't find any leaks, the TB is fully sealed and it's not a bad IAC as I didn't have an issue until after doing this mod.
I'm going to do the following tomorrow.
Unplug the IAC elec. connection. Adjust the throttle stop screw until the car either stalls or damn near, remove the copper cap and reset the computer. The TPS does not allow for adjustment, I can't move it side to side at all.
Anything else to look for?
