east_sidaz40
- May 14, 2005
- 189
- 0
- 0
I wasnt aware that dual ports have a distributor hole....Stinger said:In the distributor hole...
So if I got the commander system , does this take over the fuel mapping of the ecu? and I could keep my current ignition system and keep it distributorless?NakedRaygun said:Get an AFPR and use the stock WGA setting. 9.5 p.s.i. and no detonation will last.
You might want to invest in an innovative LM-1 or LC-1. They are $200 but you will probably need one in the future and they are worth their weight in gold.
Ah 4.6L v8's were sooo much easier
Ok done some reading , and I could keep it. I would just need to upgrade injectors and the fuel pump and put a fuel pressure gauge on. Thanks alot , finally some help from someone that is not so pessimistic about the dual plug engine. I know the internals are cast , but i'm not lookin for a hot rod , just a daily driver with more than a 100 or so hp. So , my list would bejgt58 said:So if I got the commander system , does this take over the fuel mapping of the ecu? and I could keep my current ignition system and keep it distributorless?Ah 4.6L v8's were sooo much easier
. And if I wanted to turn up the boost , just get forged internals. I'm not the one to follow the pack guys, just to let you know that, you say it cant be done , i say it can and be safe and reliable....
NakedRaygun said:Don't worry about what others say. Right now I'm in the process of swapping my friends N/A block to forged internals/turbo head/svo cam/LB3/LVAM/Low-imp 35#/255lph/24"x7"x3.5" intercooler/hy35 with stock WGA setting. So far it's come out a lot LESS than what finding a turbo motor/rebuild and upgrades would cost.
NakedRaygun said:An LA3/Large VAM and distributor/coil and turbo head would be the best idea but...
Throwing that much fuel at idle and the ECU will not know what to do with it and it will run like dog****...either get it chipped or get a megasquirt.
Thatoneguy401k but I will warn you that I'm hardly ever on it.jgt58 said:So if i did the distributor buildup you dont see any problems with my setup at 10 psi? Whats your aim screen name?
Yes, you can use a turbo computer and still run the dual plug ignition.jgt58 said:so would I still use the two coil packs and 8 plugs?
