Well, one of my life goals has been complete! I've supercharged my car. I went with the Kenne Bell kit, I believe they upgraded it to the 2.2? I think so.
Anyways, install went smooth, runs great, no detonation, but I'm having a slight problem. I went with the Boost-a-pump route because that's what KB recommened saying in tanks will mess with idle fuel pressure as well as heat the fuel excessivly.
Problem is, with the BAP turned off, under wot at 2k rpms, fuel pressure is perfect, 65-70psi. Runs great, pulls hard, very nice. However, at about 4k rpms my fuel pressure starts to drop, maybe around like 55psi. This is the problem I'm having, I'm not understanding why it's dropping.
I decided to use the BAP and turn it up, and when I do, I get my fuel pressure perfect at 4k rpms under wot, a steady 65-70psi. However, when I go wot at 2k rpms, because of the BAP, it shoots my fuel pressure up to 80psi. This is wayyyyyy to high. I can tell the car is just running rich.
I emailed KB, but they are slow to respond. Not their fault, I'm sure they get hundreds of emails a day. What can I do to fix this problem? Either way, I'm not getting any detonation, but I'm thinking that 55psi wot at 4krpms isn't good. I haven't brought it any higher than that, so I don't know what happens after that.
Thanks in advance.
Thanks in advance.
