J-Mod Question
Dusstbuster
I love meat more than anything! I just have a spec
May 31, 2004
1,462
33
64
Moorhead, Minnesota
So I've been reading up on the J-mod and remember hearing awhile back that the reason you're supposed to turn OD off in a car while racing is because you can destroy the OD gear if it shifts at WOT due to some slippage. Will the J-Mod reduce/remove this issue as far as slipping or misshifting into OD and allow you to keep OD on? I know it firms up the shifts and reduces tranny wear so I'm assuming it helps the OD shift as well?
You have brought up the biggest weakness of the 4R70W. The JMod helps shifts into overdrive but it does not correct the problem of shifting into OD at WOT. There is no fix currently that will allow a WOT shift in OD, not even a fully built 4R70W, you will break something and not neccessarily OD. I have seen input shafts break as well.
Overdive is simply not designed to take a lot of torque. The j-mod will not redesign the trans to make it something it isn't :shrug:
I know I was just hoping that the firmer shifts would help reduce the stress of the shift on OD. Whats even worse is that if it comes to that point in the RPM range and you have OD off, the tranny overrides the "off" and kicks it into OD anyways.
propellerhead said:
I have not seen any credible data on this idea of breaking something by shifting into 4th at WOT. I still think it's a myth.
http://forums.tccoa.com/showthread.php?t=67549
Still a myth?
Nothing that a tune can't fix.
wow even though i have heard of not doing that.........i am still not going to be doing that O/D shift at WOT = FTL :notnice:
and as far as the J-mod goes it's just modifying the valve body of the trans, unless you open the trans up and swap stuff out that is all your doing
