- Mar 30, 2005
- 4,749
- 95
- 134
From the master who created www.bullittarchive.com:
The rear axle is not perfectly straight. To allow the rear end to track correctly, there is about a 1 degree negative camber built into the rear axle. Basically what that means is that instead of axle being parallel with the ground, the differential is a little lower than the center line and the the top of the wheels tilt slightly towards the vehicle.
If you lift the vehicle from the differential, you are putting stress on both left and right axle housings where they meet the differential, at the same time. They were not designed to perform in this manner. Although you may not break anything, you do not want to stress this area or slightly tweak it and remove or reduce this 1 degree negative camber.
But my buddy who is a skilled mechanic says BS to this! What is the answer? It is soooo much easier to just jack the pumpkin...
I am not telling anybody else to do it I'm just not scared of it breaking
If any one has experienced a problem from jacking the pumpkin chime in and maybe I'll stop
