Junkyard Air/fuel upgrade?
mustangillusion
74
Oklahoma
Im trying to breathe some new life into my 5.0 without dropping alot of cash. I wanted to upgrade in the air and fuel department. Does anyone know of a vehicle that came factory with 24lb injectors and a larger than stock mass air meter/throttle body that will work my 5.0?
Basicly anything I can rob out of a salvage yard that will help my performance????
Also on a side note I was told that the injectors out of a camaro will work on a mustang? Thoughts on this would also be appreciated.
94-95 GT 70 mm maf sensor is calibrated for 19#'s.. dont worry about injectors which you dont need for a loonngg time.. 65mm tb off a V8 explorer.. 96-98.. it requires a lil bit of modification but otherwise it works.. have to buy the EGR spacer or just make your own delete plate.. 96-98 explorer V8 intake upper/lower and the heads are good parts..
