A friend sent me an e-mail with this cheap TT set-up for a 302 Windsor... is that the same as a 5.0? and would it work... well?
JYTurbo Parts List: Cost:
2 .63 A/R T03 Turbochargers
(one from a 85 Thunderbird turbo coupe and the other is off of a 86 Mustang SVO) $175.00
1 Set of Flowtech 1 5/8's Shorty headers (New) $130.00
3 Foot of 2.5 inch pipe (connects the header to the turbo) $15.00
2 T03 turbo exuast flanges (homemade) $0.00
2 T03 turbo exuast flange gaskets (homemade) $0.00
2 90 deg electrical conduit pieces ((plumbing) one on each compressor side of the turbo) $18.00
1 6 foot stick of 2 inch conduit pipe (more compressor side plumbing) $12.00
1 Flowmaster 2 into one (two 2.5 inch input to one 3" output this ties the turbo's together) $45.00
Misc Silicone hose and clamps $30.00
3" mandrel bend pipe for intake plumbing (purchased a box FULL at the local semi junkyard) $25.00
Total Cost of the homemade JY Twin Turbo kit $450.00
Other parts needed for this project:
75 Pro M mass air meter and 8 36psi injectors (used) $300.00
255 Walbro intake pump $90.00
Total of other needed parts $390.00
Optional parts on this Motor:
TFS-R intake $450.00
F303 Cam $120.00
Edelbrock 6037 heads 1.90 intake 160 exuast valves $950.00
Adj. Fuel pressure Reg. $ 45.00
Just a note:
Stock fuel rails
Stock Throttle body
Stock Valvetrane
Stock bottom end with 140k miles (I did replace the crank with a remain autozone crank)
Stock suspension
Performance to date [email protected] 1/8 should be good for high 10's@130mph in the 1/4
source:
http://www.geocities.com/windsor_302/TurboPartslist.html
F303 Cam $120.00
Just a note:
Stock fuel rails
Stock Throttle body
Stock Valvetrane
Stock suspension
source:
