Mach 1 Just built the wood ramps from Mustang University
BurlyStang
636
Lubbock, TX
I used to fit under my 2000GT for oil changes, but the Mach is too low for me to get under it. I found a thread at:
http://www.mustangworld.com/ourpics/News/mwramps/index.htm
which gave plans for ramps which are solid as rock. Not the cheap metal ramps that you have to prop against the wall so you can go up them. These things are solid and safe, with room to go anywhere you want. It took about three hours from buying the wood - to - driving up them for a test to make sure they worked. Easy, easy build. Cost was about $85.00. Tomorrow my 15K oil change goes in.
I highly recommend this build for easy synthetic oil/filter changes.
