Hello All,
I have been running lean (around 16.5 to 17.50) on the Wide Band O2 at WOT.
So I have been trying to figure it out.
I bought the car two years ago and have put about 500 miles on it.
1 out of ten times at WOT the engine will stutter.
I checked the timing at idle and it was set at 21* with the spout connector unplugged.
The fuel pressure is at 30 lbs. w/ vac line plugged in. No tune on car yet.
What would be a good base timing w/ 6 lbs. of boost?
The FPR is a no-boost sensitive one. The MSD 6BTM is not hooked up yet.
Thanks.
Thanks.
