Just got Accufab 75mm t/b in the mail.. install tips?
wms004
2,864
Los Angeles
will be complimenting the dragon 75mm.. wondering if there's anything i should be aware of. Is the cruise control thing hard to get off? and i dont have an impact wrench to get off the locktited tps screws but i'll try. Also don't have a volt meter (i'm at school so i'm doin my best).
-wade
Just installed a 75 mm tb & c&l plenum. I used a phillips head scewdriver that was the exact size for the screws on the tps.I also put the stock tb in a vise and used a lot of leverage on each turn to get the screws out. There a bitch to get out but if you take your time they will come out & you will be able to use them again. I have an 03 gt and there was no voltage adjustment needed. Just give the computer a couple of days to adjust itself to the bigger tb. Use a 1/4 drive set for the mounting bolts.
