Just got Dyno....
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Just got Dyno(just uploaded graph)....
And she puts out little more then i thought she was going to do.
here is what she got
HP - 240.8hp@4900RPM
TQ - 281.6ft-lb@4500RPM
ABP- 29.05 in.Hg.
VP - 0.36 in.Hg.
IAT - 82.7F
:banana:
I thought that may be she is putting 230hp or so. So i'm happy that she is putting more. But also brought some concern.
I need to scan this graph, but up until 4700RPM, power/torque curves are smooth. But past that, it starts to become sort of jagged. like up and down in small increments. like saw blade. And its became rich. up until about 4300RPM, A/F is right around +-12.5, but after that, steadly going down, and at 4900RPM, its 12.0, and continues to become rich.
So i'm thinking may be up past 4500RPM or so, she is detnating, and ECU is backing out the timing. If thats the case, then by fixing that, i should put out few more HP.
But like i said, i'm happy that she made more then I thought(even with power rubbing side exhaust). 240.8hp, with 16% power train loss, i'm putting out like285.7hp at the crank. Its my first Dyno, and it was wierdest thing ever. Car is not moving, but my speedo is sating i'm like 135mph. and some smoke came out from pipe. which i was told somewhat normal. i'll scan graph later, and post them.
Oh only thing is that my ABS right came on. is that normal???
rear wheels spinning + fronts not = ABS light
Running rich with a jagged power curve sounds like the ignition couldn't keep up. Seems like you are getting a little misfire above 4700 RPM. Or the EFI went full rich causing the misfire. Try backing the A/F ratio down above 4500 RPM and see if it straightens out the plot.
Has anyone else noticed the graphs people are posting latly aren't right?
The torque curve and Hp are suppose to cross at 5252 because that is where they are equal according to the formula
(torque*RPM)/5252 = HP the RPM cancels out at 5252 thus making torque = HP
The shift of the curve skews the numbers.....
