What alignment specs should I tell the shop I want? Best for everyday driving with a 2 inch drop.
No I dont trust them to find it out for me. I want to bring them what I want and they will print me out a sheet with all the specs on them. When I first lowered my car they said I didnt even need C/C plates. A few months later, my tires are worn to the cords on the inside.
I would find a better alignment shop after that experience.
I run as much caster as the plates allow (I have steeda ones not MM ones, but this applies to you too). Our cars can never have too much caster, except maybe if you get to the point were your massaging the wheel well. As far as camber goes, I run -2.5 deg. and I do get some wear on the inside. But since I open track the car my tires only last like 5-10k mi. anyways. Depending on what milage tire you run I think you could get away with 1.5-2 deg. neg. camber. If you run low tread wear tires run -2 deg. and make sure you rotate them often. If you run a higher milage tire go with -1.5 deg.
