- Apr 2, 2009
- 30
- 0
- 0
So I was getting codes 41 & 91. I installed new O2 sensors with the new x-pipe and fixed a leaky thermactor port on one of the heads, the codes are gone now, awesome right? Well now I got a code 46
So my haynes says it is the thermactor air bypass circuit... I am wondering if this has anything to do with how I needed to retrofit the X-pipe. All the air pump equipment is intact on the car, and the UPR x-pipe I i ordered did not have a hook up for the air pump pipe... So I welded in a little fitting, so I would pass visual, keep in mind it inserts AFTER the cat, I don't know if this has anything to do with the code 46... Will this code prevent me from passing smog? any help is appreciated... This is my last code:SNSign:
