  • SN95 4.6L Mustang Tech
Just making sure this is right.
  • Thread starter Thread starter 94GTHO
  • Start date Start date May 14, 2008
94GTHO
200
Richmond, Va
May 14, 2008
  • May 14, 2008
The other night my clutch started slipping into 4th under load so I figured its time for a new one. I was wanting a Centerforce Dual Fricition till I heard they were very aggressive and tore up the transmission if it is stock. So now I am thinking about the Centerforce II with Pressure PLate and Fidanza Lightweight flywheel. What are your guys opinions on this setup? Also are these part numbers correct for a 1996 Mustang GT stock trans.
CTF-381021-----Disc
CTF-CFT360057----Pressure Plate
FIZ-186461----Flywheel
Thanks again Stangnet
94GTHO
200
Richmond, Va
May 14, 2008
  • May 14, 2008
Also should I order a stock Ford Throwout Bearing or order the "FRPP Heavy Duty Throwout Bearing"? Here it is http://www.stangmods.com/Mustang-Throwout-Bearing-p/00755-m-7548-a.htm
Also should I replace the input shaft bearing as well.
Lastly which is the best Clutch quadrent and cable to buy.
Sorry for all the question but I am doing this all really soon and dont want to have to do it all over again later because I orded a crap part. Thanks again
BobHyatt
378
  • May 14, 2008
Couple of things:
1. Advanced sells a good clutch cable, with an aluminum quadrant that gets rid of the sloppy Ford product. The adjustment is done at the transmission end from under the car. There are some that allow you to adjust the thing at the firewall where the cable enters the cabin if you prefer that.
2. I would not touch the input shaft bearing when replacing the clutch unless you can feel slop when you grab the input shaft and try to move it side-to-side.
3. You should replace the pilot bearing that usually comes with a clutch kit, this supports the front of the input shaft where it engages the crank/flywheel.
4. You didn't mention mods. If the motor is stock, I would be very tempted to go with a stock replacement, which will cost under $150 and will work just fine. No chatter, no stiffer clutch effort, etc. I've not liked the dual-friction type clutches (two different materials, the benefit of which I have not seen). The last one I tried would chatter a lot in reverse particularly. We just wore out a zoom dual friction in 9 months, with a couple of trips to the strip per month and normal driving elsewhere...
5. resurface the flywheel for the smoothest possible engagement.
94GTHO
200
Richmond, Va
May 14, 2008
  • May 14, 2008
Thanks for the reply. The motor is stock right now but I plan for a headswap very soon so I want something other than stock along with a lightweight flywheel.
94GTHO
200
Richmond, Va
May 14, 2008
  • May 14, 2008
Anybody else have an opinion or know which throwout bearing is better?
LaserSVT
3,548
233
May 14, 2008
  • May 14, 2008
MM makes the best non adjustable cable IMO. I like the Steeda quadrent and firewall adjuster.
LaserSVT
3,548
233
May 14, 2008
  • May 14, 2008
Almost forgot. I have the Centerforce DF and its killer
94GTHO
200
Richmond, Va
May 14, 2008
  • May 14, 2008
Yea I originally wanted the DF clutch but heard it was aggressive. My stock trans is already giving me some problems so thats why I went with the Centerforce II. Which throwout bearing should I use?
D
darkside03gt
851
Sacramento CA
May 15, 2008
  • May 15, 2008
The MM cable you speak of is actaully a stock ford cable MM just removes the plastic grommet that would normanly clip into the firewall. do some reading on there site they have tested every adjustable cable out there and have found out that the oem cable is the strongest and thats why they sell it.
I have a DF clutch and i can tell you its in NO way aggressive. mine acts pretty much like the stock clutch did when i first bought the car. it grabs just a hair quicker then the stock clutch did. you can tear up your tranny more by bad driving then with upgrading a clutch.
94GTHO
200
Richmond, Va
May 15, 2008
#10
  • May 15, 2008
  • #10
so should I get a II or a DF? I want a clutch that will grab really good but wont kill the tranny. Also need to know which throwout bearing to use. I am ordering this stuff this weekend and want to get all the right stuff.
blkhorse
345
May 15, 2008
#11
  • May 15, 2008
  • #11
I bought the df(not installed). from the research I have done I found that for pedal pressure and <500rwhp that this was an excellent clutch choice. pushing >500rwhp a more aggressive clutch is prefered. pedal ease,chatter,holding power was all considered in my choice
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
May 15, 2008
#12
  • May 15, 2008
  • #12
Many people will tell you spec clutches are crap but i couldnt be happier with my stage 2
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Could not pass this up .. guess the AOD is out
  • mikestang63
  • Jun 1, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2024
FastDriver
T
What's it Worth? 1989 GT - What's it worth?
  • Tim83
  • May 11, 2021
  • What is it Worth?!?!?
3K
What is it Worth?!?!? Jun 3, 2021
Mustang5L5
R
For Sale 2000 Mustang Turbo 6 speed
  • rdwyellowguy
  • May 28, 2020
4K
SN95 Mustangs For Sale (1994-04) Jun 5, 2020
rdwyellowguy
R
