Any way you slice it, that's still a stock block. I'd be willing to try for 500 rwhp on a stock block. If I was trying for 600 rwhp, I'd be holding my breath when it was on the dyno.
ninety1 5.0 & 5spdGT, if the 70mm TB would've made a difference n/a it would've made an even bigger difference with forced induction. In this case, I think the guy will be fine with a 70mm. I'm sure 5spd could tell us what they flow, and I'll bet that it's substantially more than the heads being used. The point I'm making though is that forced induction isn't some magical quality that eliminate issues with restrictive parts. Just think about it like this: if the atmosphere on earth were 24.7 psi instead of 14.7 psi, would the ______ still be the most restrictive part?
I know that some subtle things are different, like optimized cams that prevent reversion of the airflow, and apparently harmonics and pressure waves act differently, but basic fluid dynamics remains the same. If a throttle body/intake/head is costing you 10hp at 1 bar, it'll cost you 20 at 2 bar.
Last, I think this guy is going to make a massive amount of power. With the cam, the intake, and the heads he's got, he should be well over 350 rwhp n/a and with 10 psi on top, he's going to be looking at 500+ rwhp.... Just a guess, though.
Chris
Chris
I'm doing my best over here.
