no the install isnt hard at all IMO. you just take off the alternator and smog bracket. get all of it out of the way, and punch a hole in the oil pan, which isnt hard either, alot of people get scared of it but its easy. then assemble the blower bracker and it all drops in as one piece.
if you have your smog bypassed or deleted you will need an ASP smog elim kit( i used ASP, it has the hold on the bottom that the SC installed needs to locate the alternator) i ran mine with just an unhooked smog pump and it locked up and smoked my belt..
it was pretty easy. taking my time and whatnot it took me like 6-8 hours i think. it was the first time ever installing a SC ona fox. but once its all installed and you know how it all goes in you can have it out in no time. most of the pieces are in the main blower bracker which can stay in one piece one you initially assemble it, when i have to take it out i take it all out as one units, alot easier that way.
the motor wasnt stock, it had thumper ported e7s and a b-cam with a typhoon intake, nothing special. i was running the felpro stock replacment gaskets, but i blew the, i dont really think it was 100% boost related, but i am sure the boost didnt help lol. i replaced them with felpro 1011-1 head gaskets i dont think you will have a HG problem. keep the timing out of it and the FMU should keep it fat enough to keep you in the safe zone. and still provide a huge power gain.
a s trim on your combo will make a HUGE difference
