just to make sure....5speed swap question.
140CILX-Coupe said:
I dont need to get an imput shaft sleeve do I?
clutch pedal, disk and PP, flywheel, t5, crossmember, cable, starter, TOB
and thats it?
Your Transmission should alread have the iNput shaft sleeve / front bearing retainter on it. Its what the throwout bearing rides on. You dont need the starters.. they are the same, but you do need the backup light wiring harness (wont start without it) unless you want to make your own. And as Cruzin said.. you need the driveshaft
Dr.
well yeah the driveshaft is a given but what about the harnes?
I was gonna splice the wires but I dont have a nutural safty switch it dident work when the 84 was runnin.
and what of that other damn wire on the starter wire harnes? cut it?
and the wire harness for the trans, its got plugs on it so I can remove it from the main harness or will I have to splice it?
