K-member
Also, it frees up some space, not to mention it looks better, if your into that kinda thing. As far as performance, some of them are alot stronger than stock i believe, so if road racing/Auto X is your thing...
I'd say with perhaps an exception to the maximum motorsports unit (I believe it's has practically no weight savings), all tubular aftermarket k-members are structurally more rigid….yet not as strong as the stock unit. In other words…they wont flex as much yet will fail in conditions where the stock unit will just flex and survive.
s,w,b
suspension-some change the geometry of the suspension alllowing the car to handle better in road course conditions
weight-most are lighter than the stock unit, aiding in acceleration, and more rigid, again helping in the handling area
balance-alot of tubular k-members allow the engine to site further back in the engine compartment and a little lower as well, changing the center of gravity of the car, again making the car handle better in the curves. the ideal road course car has as close to a 50/50 weight ratio as possible(50%of the weight on the fromnt half, 50% percent in the rear portion of the car).this gives all 4 tires equal traction in braking and acceleration. Talk to anyone who has one that is installed properly, and they'll tell you they love them, but installing them aint cheap or easy, so before you go buying one just because you see them in the magazines alot, you want to find alot of people who have them, and get estimates on cost and downtime on the car. If you have the money, have one put in while the engine bay is empty waiting for the new motor. just my opinion.
S&k stang - The balance won't be even on all four tires during acceleration (more towards back and/or sides)...or during braking (more towards front and/or sides)...
Anyone know the exact savings for any particular brand?
I have the GMS unit. It moves the wheels forward and inch, and has two positions for moving the engine either in the stock location or more to the rear.
With a K-member, you usually get better suspension geometry, more clearance, and less weight.
The really good ones like the Kenny brown, griggs and MM save almost no weight, because that's how much material it takes to make it as strong or stronger than the stock one.
D&D, qa1, and upr are weaker than stock. Fine for drag racing, and a weekend toy, but don't drive year around on them. They will crack, NJ roads tear these up.
The AJE and PA racing ones are pretty good, middle of the line.
subscribing...
What else should be done while I don't have an engine in my engine bay? I know engines... I know nothing about suspension. I plan on calling MM tomorrow. I'll let ya know what they say.
Chris
I would think that if the car is anything resembling a daily driver you wouldn't be focused on weight savings. I plan on swapping out mine just for a better front suspension setup. I'd hate to think that I put a weaker k-member in just to save a few pounds only to have it cracked up and then having to go through the process of replacing it - again. $$$$$$$$
Lots of good insight in here.
Only thing I will add is that if you are going with a non-OEM K member on a street-driven or daily-driven car, check with your insurance company beforehand.
I have seen collision claims denied before because the uniform structure of the vehicle was not as the insurance company expected (unmodified), despite the improved strength and integrity most aftermarket pieces deliver.
Just food for thought.
"making ours the absolute highest in quality,durability and strength while reducing 75lbs." - www.dndmotorsports.com
