k&n air intake kit or ???
csledd
Official Ovary Punching Member
1,115
Paducah, KY
I just got my 03 mustang gt and im wanting to do some small mods, small enough its not too hard to swap for dealer checks. i was looking at k&n air intake performance kits, they're pretty nice, not too pricey.. i wouldn't mind the 29 hp gain. but i was curious if there's something better out there other than the k&n?
get a tuner like the predator. run premium gas and the flash should net about 15hp. if you are concerned you can always reflash back to the stock tune when at the dealers.
BlackArtemis said:
a cold air kit is not going to get you 29hp... Mid pipe and catback, pullies?
I looked around on some more sites, and k&n says "up to 26hp gain" at resellers i see 5-7 hp gain. that 5-7 makes it sound not worth it. basically what im looking at is i got a bit of extra money this month and im just wanting to get a bit of hp gain with it, any other sugestions on the best route to do this?
btw that tuner looked pretty good
What does everyone think about pullies? worth it? I run a aftermarket amp and subwoofers and wonder if pullies will weaken the electical power from the alternater.
A capacitor (SP?) This hooks up between your battery and amps and stores power form the battery and when you music really "hits" it draws form the capacitor and not the battery. Not sure if it would help with the pullies since they work with your altenator. :shrug:
if your concerned about the dealer finding out..... then i would get intake, pulleys (preferrably black), and a tuner. however onthe 4.6's...the pulley mod is very noticable since you can clearly see the stock crank pulley with nno belt around it, attached to the aftermarket one spinning the belt. be careful
