K&N Cleaning kit didn't work...
  • Thread starter Thread starter MustangMulch
  • Start date Start date Jun 13, 2005
MustangMulch
303
Santa Clarita, CA
Jun 13, 2005
  • Jun 13, 2005
So I used the K&N cleaning kit twice already, and my filter is still dark black, covered in dirt. I think it's time to order a new filter. I have the 9" K&N conical filter. I know these filters are like $50-$60 which sucks, but I need a new one. Does anyone know the cheapest place to get one?
jpctln
198
StL, MO
Jun 13, 2005
  • Jun 13, 2005
Are you sure you're doing it right? That stuff kicks ass. Did you let it soak?
Superhereaux
chicks make me feel inadequate
538
South Texas
Jun 13, 2005
  • Jun 13, 2005
use simple green
when i bought my '92, it had the cervini 'ram air' hood and a negligent previous owner. the filter was solid black with all kinds of dirt, bugs and leaves. nasty. i sprayed (soaked) simple green into it and cleaned it three times and it worked.
not 'like new' but decent
stang22
1,318
Washington, D.C.
Jun 13, 2005
  • Jun 13, 2005
Is it stained? As long as air passes through it without any restriction, you should be fine. The filters themselves (mostly) are white, its the oil that makes them red/orange.
Tim
maverick0716
3,924
Chilliwack, BC, Canada
Jun 13, 2005
  • Jun 13, 2005
All you do is spray the stuff on and let it sit...the dirt should just pour off the filter.
G
gooch06
117
  • Jun 13, 2005
Call KN it should be covered under warranty
BrutalStang
261
PA
Jun 13, 2005
  • Jun 13, 2005
try compressed air. if not, i ditto the warranty thing. its like 1,000,000 miles.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jun 13, 2005
  • Jun 13, 2005
I believe K&N recommends not using compressed air. Spray your cleaner (K&N cleaner, Castrol Purple, Simple Green, 409) on the outside of the filter - LIBERALLY. Let it soak for a good 10-15 minutes. Then put your hose inside the filter to rinse from the inside out. Repeat a few times. Even if it's still dark in color, it should be clean and ready to go. LIGHTLY re-oil AFTER it's dry (no heat guns or hair driers) and reinstall.
maverick0716
3,924
Jun 13, 2005
  • Jun 13, 2005
Ditto what Mike said.
MustangMulch
303
Santa Clarita, CA
Jun 13, 2005
#10
  • Jun 13, 2005
  • #10
Well the first time I cleaned it, a lot of dirt came off after soaking it for 15 minutes, but the filter was still dark black even after applying the oil. I guess it is just stained then. So this isn't anything to worry about?
stang22
1,318
Washington, D.C.
Jun 13, 2005
#11
  • Jun 13, 2005
  • #11
It's probably only stained. As long as all of the dirt is out, you will be fine. Most people think that it should turn back to the color it was when they bought it. I believe most K&N filters are white, but the oil is red/orange. I also believe it is colored so you will know that you covered the entire filter, just don't put too much. MAF's don't like K&N oil.
Tim
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 13, 2005
#12
  • Jun 13, 2005
  • #12
I'll also reiterate the importance of flushing from the inside out.
K
Kerpal
400
#13
  • Jun 13, 2005
  • #13
Ditto this... I've had K&N's on a couple different cars, and I always just spray a ton of the cleaner on, let it sit 15 minutes, then rinse it gently. Repeat if the filter is really dirty. I bought a used K&N off ebay for the stang, and while it wasn't in terrible shape, it was pretty dark with dirt. After 2 cleanings it looked brand new.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Suspension UPR Coilover sleeve dosent drop down over strut
  • Creomod
  • May 25, 2025
Fox 5.0 Mustang Tech May 28, 2025
RaggedGT
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Cold Air Intake options, is this filter fine or......
  • from6to8
  • Aug 10, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Sep 7, 2024
from6to8
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
