KAM check failure code
  • Thread starter Thread starter 90stang5speed
  • Start date Start date Jan 21, 2013
9
90stang5speed
582
Columbus Ga
Jan 21, 2013
  • Jan 21, 2013
I just started trying to use my TWEECER RT on my new to me 90 mustang. I noticed in the data logs that theKAM data is always 1 and I know Im not that good at tuning. I checked for check engine codes and one of the codes I got was KAM check failed. I checked to see if i had any bad fuses and didnt have any. Then I looked for a wiring diagram and found that KAM power is supposed to be at pin 1. I checked for power at pin 1 with a multimeter and had 12 volts. dose this mean my eecm is faulty? Is there more I should check
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 21, 2013
  • Jan 21, 2013
code 15? Usually thats just from the presence of the tuner/chip, and not having an updated checksum. Ive never used the tweecer, so im not sure if it updates the checksum like it should. Lots of SCT, Diablo and soforth will have that same code because the tuner didnt address the checksum issue.
9
90stang5speed
582
Columbus Ga
Jan 21, 2013
  • Jan 21, 2013
Im not disagreeing with you about code 15 but, I havent disabled CL closed loop so it should have KAM right?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 21, 2013
  • Jan 21, 2013
Thats not what that code means all the time. Its also a ROM code. When the Checksum isnt addressed or updated, It will log code 15. Code 15 is a ROM or KAM code.
9
90stang5speed
582
Columbus Ga
Jan 21, 2013
  • Jan 21, 2013
Ok. I understand the check sum update causing the code 15. Any insite into why the KAM data is always 1 and not changing to adjust the tune? thanks for explaining the code 15
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 21, 2013
  • Jan 21, 2013
What software are you using to tune with?
9
90stang5speed
582
Columbus Ga
Jan 21, 2013
  • Jan 21, 2013
Im using BE & EA with the TWEECER RT. I would email you my tune if I knew how. Any and all sugestions on the tune would be appricated. I just did a basic tune up. Plugs, wires, cap & rotor, fuel filter and still have a miss. Im trying to get the MAF dialed in as Im using an o5 slot style in a 4" pipe thats how I found the KAM data isnt changing
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 21, 2013
  • Jan 21, 2013
I use the 05 slot as well. I used a spreedsheet that basically gave me the MAF transfer. Its actually pretty damn accurate. Did you use that spreed sheet aswell?
9
90stang5speed
582
Columbus Ga
Jan 21, 2013
  • Jan 21, 2013
could you post the spread sheet or copy & paste Your MAF transfer? I found a transfer function online but if what you have was really close, I would like to try it. thanks.
9
90stang5speed
582
Columbus Ga
Jan 21, 2013
#10
  • Jan 21, 2013
  • #10
Looking for advice on the KAM data on the EECtuner forum also. it was recommended that I check the ACT scalar and for some reason the min ACT scalar was at 200. Ive set it to 40 now and will try that out tomorrow
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 21, 2013
#11
  • Jan 21, 2013
  • #11
Yes cgrey8 is right on.
My tube diameter is different, so my Transfer wont work for you. But here is the link to a thread with the Spreedsheet.
http://eectuning.org/forums/viewtopic.php?f=1&t=18568&hilit=slot+style+maf+sensor
9
90stang5speed
582
Columbus Ga
Jan 21, 2013
#12
  • Jan 21, 2013
  • #12
thanks a bunch for the link
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Jan 24, 2013
#13
  • Jan 24, 2013
  • #13
Interesting, but should this be in the tuning section for, best answers?
9
90stang5speed
582
Columbus Ga
Jan 24, 2013
#14
  • Jan 24, 2013
  • #14
I guess you might be right that i should have posted in tuning but, at the time, i thought the problem was more mechanical. as it turns out with the slot maf i hardly reach 100 degrees air intake temp. so tuning was the fix.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jan 25, 2013
#15
  • Jan 25, 2013
  • #15
Did you use the iat in the Maf? I have the same style Maf and I am using the stock iat in runner number 5.. I didn't have this problem
9
90stang5speed
582
Columbus Ga
Jan 25, 2013
#16
  • Jan 25, 2013
  • #16
yes. I use the IAT sensor that is in the maf. I dont have a stock style intake so I cant use the original IAT in its factory location.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jan 25, 2013
#17
  • Jan 25, 2013
  • #17
Ok. I didn't have a tapped boss in mine either. I put one in..
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
N
Complex changes need help
  • nomoremasks
  • Sep 15, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 15, 2025
nomoremasks
N
