KB install, have question...
2000 4.6
927
Northern VA
Ok, I am almost done with my KB 9psi kit install. I just installed the boost a pump last night. Currently, I have a T going into the boost line for the bypass valve. I now need to T into it again for the boost a pump and again for the boost and fuel pressure guages. Is this correct? That means I will have 3 T's into the boost line. Just want to make sure that is correct. Thanks!
I hope to have her up and running tonight. I got the chip in the computer, I just need to reinstall the computer in the car. I sanded the connections on the computer down to the copper on both sides...I did notice I took a little too much off the edge because I actually sanded down a little bit of the front edges connectors. I hope that doesnt cause a problem but at the angle you had to sand at, it was bound to happen. I didn't realize that metal was so weak.
