Keep EGR spacer or ditch it?
  • Thread starter Thread starter dmac30
  • Start date Start date Mar 31, 2008
D
dmac30
Midland, MI
Mar 31, 2008
  • Mar 31, 2008
I've got the top of my motor off to replace an intake gasket and am considering eliminating the EGR spacer and bolting my throttle body directly to the intake. I'm running a Trick Flow Track Heat with the TFS EGR spacer. I've seen some people eliminating the spacer but most don't. My emissions system is completely disabled utilizing a Super Chip and most of it has been remove already. What are the pro's and con's of removing the spacer?
RYC CUKR
1,437
Orlando
Mar 31, 2008
  • Mar 31, 2008
You still need an EGR delete plate so that you can bolt up the throttle cable bracket. They are about a 1/2" thick and you can pick them up on ebay.
I did the same thing that you are talking about and used the delete plate and had interference issues with the throttle cable bracket and the FPR. I ended up making some spacers to move the bracket away from the FPR enough so that it would clear. Other than that its a bolt up fit.
D
dmac30
Midland, MI
Apr 1, 2008
  • Apr 1, 2008
Yea, I was wondering about clearance issues with my cables and the FPR. Can you get me a picture of how your cable bracket is bolted on?
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
Engine EGR spacer for explorer 65mm TB?
  • 91GTstroked
  • Dec 31, 2024
Fox 5.0 Mustang Tech Dec 31, 2024
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
