Keep the gears?
Putting stage II cams in and right now I have 3.73 gears. Should stick with those or go with 4.10s? Right now I'm at 2,800 RPM at 80 on the highway.
If you're doing a lot of freeway driving around 80 mph, then stay where you're at with the gears, at least for now. You can always change them later. Run your car with the new cams for awhile and see how you like the change - post your results. :nice:
Stick with the 3.73s and put the money elsewhere. Hitech cams really don't move the powerband that much higher. But if you have to get them, then wait until you can do axles and a diff. at the same time.
