BrightBlue00GT
I am even OLDER than Hawk!
MAJOR KENNE BELL KIT COMPONENTSGTn00b said:
• Billet Twin Screw 1700 Supercharger
• Hi-Flo Cast Alum Intake Manifold
• Billet Bypass Valve Assembly
• Bar and Plate Intercooler, HD Heat Exchanger, Intercooler Pump, Water Fill Reservoir
• Re-calibrated Chip
• 36lb Injectors
• BOOST-A-PUMP
• Fuel Rails ('00 up)
• 160° Calibrated Thermostat
It's a complete kit that will gain you 160+ hp. It's one of the most comprensive kits for the gains and the cost.
. A T/S blower is by far the most daily driver friendly blower around making it extremely trustworthy. There is not limit on going into boost in 5th gear, in fact you actually go into boost easier at high gears. There is no 5500 rpm limit. Mine is set to 6800 now. A 5500 shift point limit would be crazy. Yes, you can absolutely be at full boost/power as low as 2000 rpm, but it is all throttle position related and you don't get into boost unless you want to by stomping the throttle. I hit the throttle hard many times in low gears around town and never get into boost. T/S blowers run cooler and are more efficient, thus less strain on a motor, not more.
I love it. Yea, there's 37,000 active duty ones, an equal number of dependents, 55,000 civil service employees (govy's), a boat load of contractros and a ton of retirees who do nothing but girl watch... yea, there's a few of us
. I live in one place, work in another, and smokin' lives and works in a a completelty seperate area, but all within a 55 mile radius. Go figure. I would bet he doesn't drive though due to his rank (I assume so due to your mention of CDC's) so that limits the mobility around here greatly getting from one base to another.
x 150,000,000,000
