kenne bell or turbo???.....
The KB absolutely. Kenne Bell is a known quantity. That turbo kit looks cheesy to me from a vendor with far less reputation than KB.
Also, to turbo a 99+ properly takes twin turbo and will cost about $10,000 IMHO.
That logic is pretty lame. I mean, their may be a technical reason to back your claim.. and I definitely like the idea of two turbos over one. I don't believe that you can back up the idea the twin turbo is the proper way simply because there are two turbos rather than one.
Single turbo kits can make as much power as twin kits given the right attributes.
exactly,.. sorry mcteague your wrong on this one. Even a single turbo will out perform a KB if it is sized correctly. A single turbo can make as much or more than twins. I dont know much about this kit, but I would go to www.turbomustangs.com and do some research on this kit. They will have reviews and feedback posted I am sure.
2/>1 when it come to turbos :nice:
have you considered the 2.2L KB?
with all the extra suspentin components I would get the KB 2.2L.
this will give you insane power potential. if you are willing to drop the money for the tubro kit the 2.2L is a no brainer to me.
although the 1.7L is plenty of power for a street car.
Pro Turbo is in the May 06 issue of MMFF, Turbo Revolution. Pro Turbo apparently has been around for a while so I don't think quality will be an issue. It says you will need the tubular K, but who cares. If you have the money for a turbo, I hope you can scrape a bit more up and spring for the tubular K. I would go turbo all the way just because it's cool and makes mad hp. Good luck.
A "well designed" turbo kit IS better than a blower IMHO. The problem is finding a really great kit. Everything has to be 'balanced' properly with a turbo. I'm sure there are some really good turbo kits around for 2v motors, but based on what I've seen in some of them, hands down I'd go with a Kenne-Bell blower. KB engineers their kits really well and they are dead reliable.
Hellion makes a damn reliable kit. I know of 3 locally that have been on the car over 2 years with not one issue whatsoever,.. 875 HP on 20psi sound good enough? that is on a 4V.. but you get the drift.
I would like to add though a major positive for the KB is that it replaces the carp ford intake.
A twin kit for 99-04 is $6300 direct from HP Performance. Full boosted, they push 1000+rwhp. They also include the suspension related pieces. They aren't tuner kits, they include injectors, MAF, chip, etc. Again, that's $6300. I priced them out locally, and found them for under 6.
A 9# KB costs what, 5 grand? And that's for 400ish rwhp. So bump it up to a 14psi and max out timing, then you're now pushing the limits of the supercharger, and still making not even 3/4 the power of a twin turbo kit that costs only a grand more.
This is how I reasoned myself in to picking the HP kit. If anything, its more appealing to me because not many people do it.
