Kenne Bell with no a/c ??
jb89coupe
416
CT
Possible?
I'm thinking about picking up a Blozilla soon, but apparently you need an a/c compressor in the stock location? Right now I have the fms delete kit that moves the p/s pump up.. is there a way to run this setup?
Also, for anyone who has a KB, how do you like it? What size injectors should I pick up (street/autocross car, probably 6-8lbs)? Does the manifold put the throttle body in the stock location so I can still use my n/a powerpipe?
Thanks.
Yes... you can do it without A/C. Lack of a smog pump might be a problem, do you havee an idder pulley there now? How are you rotating your water pump? You might have to move your PS pump back down to it's original location though. It may interfere with the bracketry and snout for the KB.
Edit: disregard the portion mentioning a smog pump. Somehow I got it in my head that you'd deleted it.
No smog, no dummy pulley. Does anyone have a belt routing diagram or picture to show exactly how/where the kb pulley is mounted? What kind of "bracketry" does it use that my p/s pump would be in the way?
Thanks! :nice:
