Kick panel question from a newbie
  • Thread starter Thread starter A_Code_Kiwi
  • Start date Start date Aug 11, 2005
A_Code_Kiwi
Formerly New Zealand, Currently Canada
Aug 11, 2005
  • Aug 11, 2005
I'm about to install new kick panels in my 66 mustang and was wondering where the screws go. Is there a factory location for them or do you just put them in anywhere? The old ones I took off did'nt have any so they're no help at all. It probably sounds like a stupid question to ask but I'd rather do the job right than half assed
If any one can post a pic or tell me where they go it would be much appreciated.
mfp4073
387
Hells Ditch, FL
Aug 11, 2005
  • Aug 11, 2005
Every kick panel I have ever seen has screws. the kicks should have holes in them and the metal behind them should have holes too. Mind looked like the originals were just put in there...a hole was knocked in there and the screw was added.
NOOOOO no stupid questions..every one of us was a newb once..anyone that tells you different is a jackalope lier! Welcome to the boards!
65up2d8
281
Memphis, TN
Aug 11, 2005
  • Aug 11, 2005
I also would like to welcome you. I am confused, however, by your question. The kick panels you have don't have screw holes? The kick panels on my '65 did. Can you post pic's of your kick panels?
65Mustang2+2
118
Connecticut
Aug 11, 2005
  • Aug 11, 2005
I bet the old ones are repro's and thats why they dont have the screw holes in them, and the new ones wont have them!
G
gjz30075
250
Roswell, Ga
Aug 11, 2005
  • Aug 11, 2005
I have two screws in mine with the Pony Interior. One screw was dead center in the panel, just above the chrome strip and the other was in the lower corner, near the sill plate. I'm told these are the correct locations but I'm skeptical. However, I've seen '65s with two screws in the carpeting part of the panel, about two inches apart, dead center. That was on a 13,000 mile car, all original. That all said, I, too, would like to see where they really go, as I've seen them all over the map. Mine are currently out for refurbishing.
6Stang7
1,470
Livermore, CA
Aug 11, 2005
  • Aug 11, 2005
screw holes in the kick panels? never heard of that. i just got some new ones for the 67 and there were no screw holes in them.
Cobain03
996
Lexington, Ky
Aug 11, 2005
  • Aug 11, 2005
oh man, my screw holes are killer, takes forever to find them, IF you find them. i got fed up and did new holes. also on the speakers, did you have ot buy super thin speakers? cause mine hit the metal.
A_Code_Kiwi
Aug 11, 2005
  • Aug 11, 2005
You're right. They are repro's. I bought them from americanpony.com. The only picture I've been able to find of kick panels with the screws in them is from the Mustang 1964 1/2 - 1973 Restoration guide by Tim Corcoran and Earl Davis and even that picture was really hard to make out being in black and white. I guess it'll be the same location regardless of whether you've got deluxe interior or not right either way it's a dang site better than having the ones the previous owner butchered trying to put speakers in.
6Stang7
1,470
Livermore, CA
Aug 11, 2005
  • Aug 11, 2005
they are 180watt sony xplod 6.5". they did hit on the side, so i persuaded it with a hammer. fits fine now though.
snowball
44
Melbourne, Australia
Aug 12, 2005
#10
  • Aug 12, 2005
  • #10
I had a similar problem on my ute and solved it by cutting a spacer out of 19 mm MDF to bring the front of the speaker out from the kick panel a bit. Spacer screws to the kickpanel and the speaker screws to that.
6Stang7
1,470
Livermore, CA
Aug 12, 2005
#11
  • Aug 12, 2005
  • #11
i thought about doing that with some black ABS i had, but i didnt want the speaker to stick out too far, so i decided just dent the metal in a little since i was barly fitting to begin with.
19simmons65
214
Upper Marlboro, MD
Aug 13, 2005
#12
  • Aug 13, 2005
  • #12
I had a similar problem when I tried installing my Pioneer speakers. I used my old beat-up kick panels as a templete to mark the holes on the new kick panels. I then used a drill to make the holes.
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
Resolved Fuel Pump issue - test port jumped comes on (87 LX)
  • afjLX
  • Nov 16, 2024
2K
Fox 5.0 Mustang Tech Nov 26, 2024
afjLX
A
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
