  • 1994 - 1995 Specific Tech
Kickdown adjustment
  • Thread starter Thread starter bigbear89406
  • Start date Start date Feb 20, 2009
bigbear89406
37
Fallon, Nevada
Feb 20, 2009
  • Feb 20, 2009
Been tring to research and cannot find anything on it but does anyone know how to adjust the kickdown cable on a 94 stang with an auto.
toyman
1,944
54
79
Vernon BC
Feb 20, 2009
  • Feb 20, 2009
There is no kickdown cable. The transmission is electronically controlled through the PCM. What is the downshift issue you are concerned about?
bigbear89406
37
Fallon, Nevada
Feb 20, 2009
  • Feb 20, 2009
kickdown
It won't kick down in low speeds shifts fine at like 55 mph just low speeds won't kick down.
toyman
1,944
54
79
Vernon BC
Feb 21, 2009
  • Feb 21, 2009
Perhaps someone more familiar with the AODE will step in. I'm thinking that it may be either the Shift Solenoid and/or the electronic pressure control solenoid. I assume when you state that it shifts fine at 55 mph you mean at WOT it downshifts from OD back into 3rd but at lower speeds it won't downshift from 20 mph going to WOT back into 1st.
HISSIN50
34
129
Feb 21, 2009
  • Feb 21, 2009
The factory tune sucks for the shift thresholds. Wes can tell you what the exact shift points are. I can't remember.
If it's acting really screwy, check your TPS since it's important in telling the EEC how far you've matted the pedal.
Good luck.
bigbear89406
37
Fallon, Nevada
Feb 22, 2009
  • Feb 22, 2009
thanks guys
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
