Klean-strip
  • Thread starter Thread starter Fireman255
  • Start date Start date Sep 22, 2005
F
Fireman255
119
  • Sep 22, 2005
using a combo of Klean-strip stripper and sanding on the car.....curious if anyone has experience with Klean-strip rust converter?
also tips on removal of window trim and drip rails would be great
Thanks
65nProgress
53
  • Sep 22, 2005
I can't help on the drip rail removal but I just took my front glass out. The trim is really easy to take off once you get the hang of it. I used a putty knife and it worked fine. Basically I used the knife to carefully rock and pry the molding up to loosen it. The old sealer had it stuck on tight. Then what you need to do is locate where the clips are. Once you've done this, you can gently pry up with the putty knife. I found it works best if you can get the blade under the bottom edge (edge that the clips attach to) of the moulding and pry slowly. I did this and every clip released fine and with no damage to the moulding. The hard one was the cowl trim since its one long piece. Very easy to bend. You can also buy a tool to assist you in the removal.
hope this helps.
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
Rust under side window weatherstrip
  • swe13
  • Jun 5, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 5, 2025
swe13
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2026
skidad
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
