Knocking/Detonation? HELP!
DRock9
359
So I planned it out so I had just enough gas to get to school and then to the gas station today but my mom decided to warm up my car not knowing how little I had. So it ran out of gas, what is the possibility that something was damaged? I didn't know if that was the problem so I tried to start it a few times before I decided that it was.
My mom told me that we had some more gas in the garage, so I put some in but I noticed that it was clear when I was pouring it...I thought gas was yellowish, it smelt like gas. I stopped pouring it once I noticed that, but my mom needed me to move my car because she needed to get to work and my little brother needed to go to school. She went out there and tried to start it and it would run really realy rough and then die, I went outside when I heard her try to start it and I noticed a loud "pop" noise coming from under the hood from time to time...was that detonation?
I can't even get it to start right now, its making all of these weird noises...its about -20 windchill right now and probably reaaal close to 0 so that probably has something to do with it since it never starts good in the cold.
What is wrong and what could have been damaged? Reccomendations on what to do? Take it to get it checked out?
Maybe this will give me an excuse to build that 306 i've always wanted to, and now that I got a good job maybe I will.
I can get it running kinda if I feather the gas, but it idles at like 700...600...500...Dead. And it sounds like I have a real lopey cam so I am not sure if all the cylinders are firing or not, but there is a very distinct popping noise coming from under the hood(I think) as I described above.
Anyone know whats happening?
EDIT:
"POP: This sounds like a shotgun being fired through a mattress. It usually means the engine's coughing back through the intake.
A sticking or leaking valve is a distinct possibility, as is jumped valve timing, particularly with a belt-driven OHC.
Then there's ignition, which may be firing way too early due to a twisted distributor, cap/rotor/wire problems, a faulty position sensor or a breakdown in the module.
Also, if your car's running quite lean, opening the throttle to lots of cold air can induce this reaction."
Any of that make sense?
Sounds like you have some bad gas: it may be mineral spirits, which is clear and has an octane rating of almost zero. I would siphon or pump it out and put some fresh gas in it. The Schrader valve near the alternator is a good thing to use to pump out the gas. Remove the valve core and put a suitable hose that goes to your catch bucket. See the diagram on how to jumper the test connector so that the pump runs anytime the igniton switch is in the run position. Just be sure to shut it off quickly when you see the fluid quit flowing out the hose. Fuel pumps don't like to run dry, it can damage them.
attachment.php
I agree with the bad gas. I can't think of anything that could have been physically damaged by running out of gas, with the possible exception of the fuel pump, but running for just a moment with no gas probably wouldn't damage it.
Get that old crap out and get some fresh gas in there, it will probably fire right up.
The fuel pump makes a very wierd sound when I turn my car on now...its like a low humming sound rather than a high pitch whine like it used to be. It cranks over but it just wont start up and idle...ill try to siphon it out but the fuel pump part is bothering me.
Thanks!
EDIT: I just poured more 87 octane in it, I talked to my Dad and he said the smaller container had a mix of oil and gas in it...so right now there is like 7/8 87 octane and 1/8 Mix(Oil+Gas). I got it running and it starts fine but there is a lot of white smoke coming out of my mufflers so I am pretty sure that there is some oil in the gas, but can it harm the car? The fuel pump is still making the low humming noise but it seems to be a little better, there is still the small knocking/popping sound occasionally and it really hesitates when I floor it in neutral but both have gotten better aswell. Would it be bad for my car to have this running through it?
While I was under the hood I also noticed a faint screeching noise, definately metal to metal, coming from the passenger side. Maybe a bearing is worn out or something?
Thanks for any responses!
You would have been better off to put some 93 octane in it. The 87/oil mix is a lower octane than straight 87 octane gasoline. The extra cleaning agents in the 93 octane gas are good for the fuel system.
Yea the 87 octane was mixed in with the tank at first, but I just put in a little over 11 gallons of 93 octane to help clean everything out.
As far as the noise, if I position myself in the middle of the engine standing next to it on the passenger side, its coming from somewhere in it if I look down. It doesnt make the same noise on the drivers side.
