  • 1994 - 1995 Specific Tech
knocking engine
  • Thread starter Thread starter k-man
  • Start date Start date Jul 27, 2009
k-man
spokane, wa
Jul 27, 2009
  • Jul 27, 2009
i just got a 95 gt, had a bad vibration at idle and found that the harmonic balancer had come apart, so changed it out with one off parts engine and now runs smooth.. and yes it is 50oz had same part number as old one..
but now that all is fixed the car has a rod knock, guess the guy ran it long time messed up.
so anyone know if i yank the engine and just replace the rod bearings if that would be all i need or replace the mains also?
66sprint6
131
Jul 27, 2009
  • Jul 27, 2009
Wont really know till you tear it apart. Funny thing is, i went thru the exact same progression somewhat. Noticed the balancer wobbling a bit, replaced it, motor started knockin, piston broke off rod and engine went BOOM lol. Tear it apart and see!
Matt
Adam95GT
2,564
Burlington, NJ
Jul 27, 2009
  • Jul 27, 2009
crank might be shot....
k-man
spokane, wa
Jul 28, 2009
  • Jul 28, 2009
sounds like my good deal is not as good as i thought
rock4451
20+ Year Stangneter
Nov 30, 2004
12
New Baden, IL
Jul 28, 2009
  • Jul 28, 2009
sorry to hear that man, i got a good deal too and thought i was in for the same. turned out to be a header leak
Dino Dino Bambino
1,672
89
79
Cyprus
Jul 28, 2009
  • Jul 28, 2009
I think it's more than likely the main bearings will be shot. Just cross your fingers and hope that the crank journals won't need to be reground.
302GTS
If you need herpes, I'm your man!
Apr 20, 2009
481
Largo, FL
Jul 28, 2009
  • Jul 28, 2009
Hopefully if, as soon as you noticed the knocking, you parked the car, the damage won't be too bad... A friend of mine with an N/A 300zx chipped his car and it brought the rev limit to 7,800, even though his cams ran out of juice by like 5-6 grand... He constantly revved it that high, and ended up getting a knock about a month ago. Instantly shut the car off, towed it to his shop, we tore into it and just found a single spun rod bearing. The rest of the rotating assembly looked just fine, so I hope you have the same luck!
On the bright side, if the internals are unfortunately shot, 351 swap?
k-man
spokane, wa
Aug 2, 2009
  • Aug 2, 2009
thanks for the advice everyone! i did park the car right after replacing the balancer right when i noticed the knock.... well and for the fact that the same night the auto trans in it decided to only work in 1st and 2nd gear
going to yank the engine-trans, replace the mains and rods. i got a crank from my friends engine that he put a 331 stroker kit in.. same engine that the balencer came off of.
does anyone around the washington-idaho area have the parts needed to convert to manual trans??
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 14, 2025
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
