  • SN95 4.6L Mustang Tech
knocking noise from motor
  • Thread starter Thread starter Red98StangGT
  • Start date Start date Feb 23, 2006
R
Red98StangGT
  • Feb 23, 2006
Alright this is what i got, its a 98 gt automatic trans, recently it has started knocking on cold starts and when it is reved to about 2 grand. ive had a guy tell me it is one of the rods on the lower end , and what im needing to know what would be cheaper,, to fix the problem and build the bottom end stronger, or to just pull the motor and start with a different one? and also would the 96-98 cobra motors match up with my auto tranny or not? just any little bit of info would help me. . . . thanks
Built98GT
211
OKC
Feb 23, 2006
  • Feb 23, 2006
From my experience with the block i just built it would have been cheaper just to buy an already built block from vt engines or some other company.
R
Red98StangGT
  • Feb 24, 2006
ok thats what i was leaning toward anyways, and do you know about the cobra engin matching up with my trans
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 24, 2006
  • Feb 24, 2006
does the knock go away when warm? how does it run? your engine may not be blown.
the98stang
2,408
Clovis, CA
Feb 24, 2006
  • Feb 24, 2006
What oil are you running?
If the oil is too thick it won't reach the parts quick enough and cause knock. If it's a slight knock and only in the morning you should be fine...
Mike97gt
it doe snot
10,633
Feb 24, 2006
  • Feb 24, 2006
also make sure you use a oil filter with a anti drainback valve.
D
dbmiller
  • Feb 24, 2006
my 98 cobra has a ticking noise at about 2000rpms when driving, it sems to go away above that. I run synthetic oil. engine has 100k, it comes and goes i dont know what cause it. any suggestions. db
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
