Knocking Noise When Shifting
  • Thread starter Thread starter DRock9
  • Start date Start date Sep 25, 2006
D
DRock9
359
  • Sep 25, 2006
There is this weird knocking noise when i shift, i hear it the most going into 2nd and 3rd. It happens right as i let off on the clutch and step on the gas, my Dad said it might be a bad u-joint. I usually shift below 2k to try to save gas and thats when i hear it the most, because its quiet in the car. Whenever i shift at 2.5k+ i can never hear it so I can't tell if it happens or not. So i have two questions:
Does anyone know what this knocking noise could be?
And also, is it bad for the car to shift at low RPM's as long as it doesnt buck and jolt? I can shift below 2k very smoothly, the only thing that happens is the knock I am talking about.
Thanks for any and all help!
88gt
794
Drillers cabin
Sep 25, 2006
  • Sep 25, 2006
First check the bolts at the rear flange of the driveshaft and make sure they are tight. If so, remove driveshaft and get checked for balance/bent/u-joint problems. Around here, all that would run you abour 60-85 bucks.
As for the short shifting....not a problem as far as I know. I've short shifted several times...no problems by doing that.
Jim
Mavrick
2,264
Collingwood, ON
Sep 25, 2006
  • Sep 25, 2006
A bad U joint is pretty easy to spot on your own.. put the rear end on stands, slide under the car and inspect the u-joints and driveshaft.
T
tylerdred
75
Chicago, IL
Aug 4, 2007
  • Aug 4, 2007
Same Problem
i was wondering if anyone knew the answer to this question because my 89 mustang notch 5 spd starting making that same noise too....any advice? do I need a new tranny?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Aug 4, 2007
  • Aug 4, 2007
Definitely sounds like universals to me.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Aug 4, 2007
  • Aug 4, 2007
or controll arm bushings or cracked or torn torque box (boxes)
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
