KOEO code 32
So what is this mystery code? I used the Autozone scanner to pull it and their database doesnt have Code 32 listed.
Yes, I'm sure I've read it right. Read PLENTY of trouble codes before... Can anyone fill me in?
Only other codes I'm getting are 11 at KOEO, which is normal....and 41 and 91 at KOER. Which are both incorrect because I am running as close as I can get to stoich. I bumped fuel pressure just to be sure, and still got lean codes, even though I was running pig rich and lost MAJOR power.
Thanks.
Autometer *****? Like a gauge? Hell no. I wouldn't run one of those O2 gauges unless I were running a wideband O2, otherwise, whats the point? And if I were going THAT far, I'd probably run a pair of wideband O2's, to two gauges so I could monitor the left and right cylinder banks independently.
Yes, I've read the plugs. Light tan. PERFECT. At 40 psi, the plugs read too lean. 45 psi, it runs pig rich. I'm running 42 psi w/ vacuum right now. Runs best at this level. Like I've said, I KNOW the car is not lean. Just for some reason, my ECM thinks it is. O2's have maybe 20000 miles on em.
heres wut i woud do clean alot of stuf on the car while cleaning leave both pos and neg off the car for 30 mins or buy a egr from the junk yard it cant be that much give it a try
i was about to add, when i realized that you had the thread that JR et al posted on. they summed it up pretty well, i thought. what are you trying to find that they did not explain? (not trying to be a smarty pants, but it is hard to do better than JR's info). :)
Hissin50, thanks for the vote of confidence.
Since this is an educational place and many of us are trying to lean more, I will repost my earlier comments with some additional info...
Code 32 - Code 32 – EGR voltage below closed limit
Let’s put on our Inspector Gadget propeller head beanies and think about how this works:
The EGR sensor is a variable resistor with ground on one leg and Vref (5 volts) on the other. Its’ resistance ranges from 4000 to 5500 Ohms measured between Vref & ground, depending on the sensor. The center connection of the variable resistor is the slider that moves in response to the amount of vacuum applied. The slider has some minimum value of resistance greater than 100 ohms so that the computer always sees a voltage present at its’ input. If the value was 0 ohms, there would be no voltage output. Then the computer would not be able to distinguish between a properly functioning sensor and one that had a broken wire or bad connection. The EGR I have in hand reads 700 Ohms between the slider (EPV) and ground (SIG RTN) at rest with no vacuum applied.
As vacuum is applied, the voltage on the slider increases (EVP). As the voltage increases, the computer knows the how much the EGR valve is opened and how much exhaust gas is being recirculated. It uses the load table to calculate the amount of exhaust gas required depending on RPM, Mass Air Flow, ACT, ECT & TPS. It then sends a signal to the Electronic Vacuum Regulator to hold, increase or decrease the vacuum being applied to the EGR valve.
Theory class is over now, let’s spin up our propeller head beanies and get with it… Go Gadget, Go…
Measure the resistance of the EGR sensor between the two end pins. You should see between 3500 to 5500 Ohms. With the sensor removed, measure the resistance again while pressing on the plunger. You should see the resistance drop from its high value to a low reading of 200-700 ohms depending on the sensor. No resistance readings, or values way out of range, the sensor is bad.
If the Orange white wire has Vref, (5 volts =/-.25 volt) then you have some wiring problems because the computer isn’t seeing the minimum voltage on the EVR pin. Ohm the wiring back to the computer. Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1 ohm. Repeat the process for the orange/white wire and pin 26. Do it again between the black/white wire and pin 46. In no case should you have more than 1 ohm. Remember that resistance checks are always done with the power off the circuit.
Voltage and resistance checks are good: Here’s an EGR test procedure I copied from cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve
apply 5 in vacuum to the valve.
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect vacuum gauge to the hose coming off of the EGR Valve
snap throttle to 2500 RPM’s (remember snap the throttle don't hold it there).
did the vacuum gauge show about 5 in vacuum?
if not, check for manifold vacuum at the EGR vacuum valve.
if you have manifold vacuum then connect vacuum gauge to the EGR valve side of the vacuum valve and snap throttle to 2500 RPM’s.
should read about 5 in vacuum
End of cjones's test.
If the test procedure fails to provide proper vacuum, check vacuum feed lines for cracks & damage. If the vacuum lines are good, check the electrical wiring to the EVR. If the EVR electrical wiring is good, look for 12 volts on the red wire for the EVR. If the 12 volts is good, look for a varying voltage on the dark green wire on the EVR. Case of last resort, replace the EVR and then the computer
