KOER code 13
I'm simply trying to get the car to idle over 725 RPM (I like 900 RPM) and there seems to be my issue causing KOER code 13
That is the issue because the car is trying to lower the idle down, while you are bumping it up.
Do you have a reason for wanting a higher idle?
Basically thre idle set procedure is to unplug the IAC, adjust the throttle stop screw to desired engine RPM and then reset the cmputer and plug in the IAC. The IAC can raise the idle up (cold start, imminent stall, engine load) but can't lower it due to the throttle stop screw holding the plate open.
You can bump the idle up with the throttle screw, but if the idle is over 725RPM the computer will always trip the Code 13 as it's trying to lower the idle.
You may also come across a TPS code if the idle voltage is out of the 0.6V-1.1V initialization range.
Reactions: jrichker
Yes I do....when idling at 725 or so the idle is hardly smooth...like it's requiring more air. It may be due to my camshaft but not sure as the camshaft is a Crane 2030 (.533/.544 lift 216/220 duration 112 lsa). When I get the idle closer to 900 RPM or so the car will idle in the way I think it should....
