Koni’s
Reddevil91
1,630
773
163
Hey guys back in it again, so I figured while I’m in the process of brake swap, that maybe I should put some new struts and shocks in. So came across these from a guy I picked up the SN95 spindles from. He is going full drag car and has these Konis he just texted me about. He said they are in great shape, maybe put about 2-3k miles on them.They look clean and all together. He says he wants 200, I know these go for around 600 I think. Is this a good deal or should I let them pass?
I had these on my car a few years ago before upgrading to a stiffer road race style suspension. They are a good stock upgrade for the street. They are not designed for drag or road race type of suspension.
The Koni struts/shocks you are thinking of are yellow in color that come it single or double adjustable forms.
52B5E384-AC7E-4927-A4EA-27A200ACD814.webp Ahhh yes, well I guesstimated haha but maybe I’ll try 175. Was going to grab some KYBs for 189 for the set of lmr but then got this offer and wanted to see if ppl thought this was a good deal or would pass. Won’t be doing any track or drag strip days. Would think these have to be better than the Monroe shocks and racecraft struts I’ve had on since 1999. Also I have Jamex springs currents but after the brake swap I plan on going with some 18s. If I remeber correctly the Jamex springs dropped the car 2 inches all around. I love that lowered look but what are some springs ppl are going with now day? I have 17 cobra r’s currently and as it sits, it’s tight on those. So maybe offer 175 and pull trigger or get something new like KYBs?
Does the adjustableness really matter. Seems like the reviews I’ve read most ppl stick to only one of the settings due to the other being to bouncy
The Koni's in my opinion are a better setup, and are defiantly better than any autoparts store Monroe set you have now.
KYB's are about the same as the Monroe's just a cheap factory style dampener
Reactions: A5literMan
You only need to go with adjustable when doing more than just street driving or need aggressive settings that standard strut/shocks provide.
With your plans I would stick with the STR.T
I haven't needed to do it with the 245 series tires I have been running. Are you planning on running 275+ width tires?
I’m not real sure what size I’ll go with yet. I’d like a little meat on the back but then that would take me back to will it fit, do I need to take my quads off. Just seems like I’ve seen a lot of chatter about ppl doing the fender roll but don’t know what all it intails or how much I need to do if I do, or if it messes anything up.
Buy a coil over spring setup (maximum Motorsport is what I used) for the front end. You can adjust your ride height and order the proper spring rate for your desired driving. Not the cheapest route but it was the best setup I ever ran on a Fox. I had strange adjustable struts and MM cc plates also.
4DCA5CC0-A1A6-4DE1-B6DF-4677722AC53A.webp 049A2306-DF9F-4FAE-B8EB-46F6EB620495.webp
Those konis are fine for a street car but I wouldn’t over more than 150$ and I might spend 175$ max
I got him down to 175 currently, again he seems trust worthy, they do look clean and the bushings look to be in good shape. He does keep trying to bundle me with some subframes which maybe if I can get it all for 200 I’d take it. He seems to be wanting to get rid of them. I’m looking into MM bare full lengths for 155 on lmr, what do you think. I would be just a street, weekend car. I know something is better than nothing. Are these worth while subframes wise?
For the coil overs I’m guessing one would surely have to have adjustable struts correct.
