Koni’s
For the coil overs I’m guessing one would surely have to have adjustable struts correct.
Nope. You don’t have to have adj struts. I would recommend but again if you are never going to race/change the settings, etc then plain Jane struts work fine. The MM coil overs are designed for specific brands(Koni is one of them) so you won’t have much noice/rattling etc. Also I highly recommend some frame connectors even if you don’t race. Always nice to stiffen the chassis on a subframe car.
Cool thanks for the info. So I know the subframes he has say bolt on, and that I can get them welded which I would do. Would you say those are worth it or just stick to the full length MM ones?
I went with the Koni''s and Eibach proline springs, both fit my budget and needs. I'm happy with the height and as mentioned the Koni str.t shocks and struts are an improvement over the factory and lower end stuff but have no adjustability which was fine for what I use the car for.......which is basically not much :rlaugh:
Ok so went to check out the struts and shocks and I don’t have much experience but they seemed soft like easy to compress. One of the struts compresses and then really didn’t want to rebound. I decided to wait and see if this is how they should feel. I was compressing them easily with one arm as you can see. Something told me to pass and see what others thought.
View: https://youtu.be/RcvV9YKLI3A
View: https://youtu.be/9eyUVkoLBms
What was the softness on your struts and shocks when you got them?
I'll be perfectly honest with you because they were new I really didn't play around with them at all, just slapped them in after fighting with the damn coil springs, but my experience with other shocks is that they don't take a whole lot to compress but if your nervous at all just get new ones.
