LABOR COSTS
jimdrechsler
248
I am having upper control arms/lower control arms, and torque box reinfocements installed on my stang next week. how much would someone pay for labor on installing everything?
thanks,
jim
Why cant you do it yourself? You just need a jack and some basic hand tools. Are those reinforcements welded in or bolt in. I've never done them but plan to, but it looks like you just pull up the carpet from inside and install them above the boxes from the inside. I'm a Master ASE tech and knowing Mustangs I would say the arms should cost 1 to 2 hours depending on how long the tech thinks it would take. I'd go there with the interior already pulled up and have all the instructions there and ready. If the boxes are as easy as I think they are, you shouldnt pay more than 3 hours all together. Usual labor rate is roughly 80/hr so figure around $200-250. On something like that, to them its custom so dont let them jerk you, most shops barter. If its too high an estimate then haggle, and go there when its really slow and they'll take in anything. Also, if its really slow you'll get multiple techs on the car for free because they'll be interested and bored.
I would expect to pay 2-300 for this kind of work...
I'm not saying it is worth that much money, but that is probably what you will be charged...
Have I mentioned that I HATE going to shops?
Call a couple of shops before you start driving around...
Many shops won't even consider jobs like this...
(you may want to pull the carpet/rear seats out of the way before they start welding on the torque boxes...)
jason
if someone has already talked you into putting UPPER control arms on a 90 LX, you're already in trouble. they dont have upper control arms. there's a lower CA, a spindle, and a strut. and since i took my lower CA's out today, i now know that fords moron engineers were not talking to each other again the day they designed the control arms and the rack and pinion unit. the rack has to be unbolted from the crossmember and the steering column and moved forward a good 2" just to get the drivers front lower control arm bushing bolt out. the other 3 come out fine without having to remove anything else.
why are you replacing your control arms? its a lot of work for no real benefit that i can see, unless youre into competitive road racing. mine came out because i was putting in lowering springs and figured it was as good a time as any to put in urethane bushings.
id be willing to bet the price will be twice whats already been mentioned, assuming you can find a shop that wants to take on the project. like mentioned earlier, if you can wait until post-thanksgiving time, the price and the number of shops willing to do the work will be in your favor.
That is not a job to do on your back!!!! F- that!!! I put mine on both my cars myself. I have a hoist, many tall jack stands, a come-a-long, hand tools and air tools. Hand tools WILL NOT cut it. If you have rust or corrosion, forget it...you are not getting the bolts out. Some times the rear end will tilt, this happened to me, and it was hard to get the upper control arm bolts back in. I used the come-a-long to get it back where I needed it. Without the hoist this would not have been possible. A friend would be a big help too!!!!
You also have to drop the exhaust from the front bolt on the lowers!!! If you have old exhaust good luck!!!
oh, the rears....doh! ive spent my weekend ripping out my front suspension and thats hwere my mind was. i took my rear out last week to have a ring and pinion swap. removal was easy. like mentioned above, the mufflers are in the way of the lower CA to frame bolt and have to be removed. i havent got the rear back to put it in yet so i cant tell you if its a pain in the ass or not yet, but i should get it back today.
$250 would be reasonable for a rear job.
man that sounds dirty...:shrug:
thanks for replies. i have a "guy" i take all my stuff to. he works out of his garage and can pretty much do anything and everything. this gives me a rough estimate of what i will pay. he is always cheaper than going to a shop. so i nkow that i wont pay mopre than 250-300 for all of it which is good. i am also going to have him drain and fill the tranny fluid too. i am having him weld the torque boxes in. doing everything right the first time i hope! however, i am keeping thepolyurethane bushings on the UCA's as opposed to switching them out as someone recommended in another post. i hope it wont make that much of a difference!
I did my control arms no problem on the ground using three jacks and two jack stands...it was a pain and I had to get very creative with the jacks to move the axle to where I needed it.
You can do it!
maybe do a little research to make sure about this. i have read that it can cause some issues with binding in your rear suspension...
anyone else have info on the bushings?
Yep... go to the Maximum Motor Sports site and read their writup on their LCAs. The recommend the 94 Up uppers for rigidity and factory rubber bushings to prevent suspension bind. This of course, is for steet driven vehicles.
UCAs and poly bushings are bad ju-ju. You won't feel the bind until it's too late. It'll release and you'll end in an unrecoverable (in most cases) fish-tail.
DAGGAR-
where can i buy some of these locally? is it possible? or do i HAVE to go thorugh Maiximum motorsports?
thanks,
jim
i just got off the phone with MM and it looks like i have to use the edelbrock ones i got. his will not replace the pollyurethane ones in the edelbrock ones i got. i am hoping with the torquebox reinforcements welded in there, i should be good to go!!
You can get the bushings from advance auto parts, oreillys etc... thats where i bought mine, they were the MOOG brand. Even though you only need the 2 front ones, you have to buy them in a fron & back set, so youll have to buy 2 sets to get 2 front bushings.
By the way, if you pull the carpet up and remove all that seal seam glue yourself, youll save some labor time there. That is, if they are welding the plates in. (like they should) if they are just bolting them in, i would get the back seat out, and pull the carpet up and do anything to save them time.
If they are welding them in, and they dont get all that seam seal glue stuff out, the welds wont hold right.
OK, here is what i bought.
http://store.summitracing.com/partd...925130+4294839061+4294848363+115&autoview=sku
can someone tell me EXACTLY what I need from advance auto so i can buy it before i drop it off tomorrow night. part number would be great!
Thanks for all the help. i want to do this right the first time!
ALSO... any advice on where these should be adjusted to would be great so i can tell my mechanic. im sure he owuld probably know, but it could help?
