Large vs Small 9" bearings
brianproctorla
50
I am considering buying a 9 inch from a 57 Ranchero for a 76 stang
Previously I had bought 10 x 2.5 rear drums from an 86 lincoln for future use on a small bearing 9".
The backing plates will not work with the ranchero large bearing.
Can this be re-drilled?
Are there any advantages associated with the larger bearings or the ranchero 9 inch in general?
I might wait for a 57-59 passenger 9 inch in order to keep the brakes
I appreciate the help. I think I am going to hold off and wait for a small bearing rear. I've also heard that there are more options, as far as disc brake kits, for the smaller bearing.
If I had not already bought the 10 x 2.5 drum brake setup, I would have considered this swap and gone with 11 x 2.5 rear brakes with redrilled drums.
I have a 1957 Ranchero big bearing rear end. Yes there are more disc brake options for small bearing rear end. I'm running Bronco big bearing drum brakes on my '57 now (11 x 2.25). I would opt for the small bearing rearend now.
