late 80s 5.0 help needed
  • Thread starter Thread starter CR144968
  • Start date Start date Nov 14, 2019
First Prev 2 of 2
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 16, 2019
#21
  • Nov 16, 2019
  • #21
Please list the numeric values for the codes and I will give you the Mustang specific code definitions and fixes. The codes need to be sorted out first and then use the code data to get pointed in the right direction.
C
CR144968
10
Phoenix Arizona
Nov 18, 2019
#22
  • Nov 18, 2019
  • #22
I am trying to get ahold of an OBD scanner so I can make sure, but if I am counting the flashes correctly, the codes are, and in this order, 81, 82, 85, 84.
The light I am reading is not an actual check engine light as the car does not have one. It is just a bulb and the light sort of double flashes-making the counting a bit harder. I have a video of it-is it possible to upload that to this site so I can get a second opinion.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Nov 18, 2019
#23
  • Nov 18, 2019
  • #23
Air injection solenoids, charcoal canister and code 84 is EGR related, which I assume is also deleted?
None of those codes really affect how the car runs. Code 84 disabled the EGR function in the ECU.
Resistors should be able to make those go away. You just need to know the correct values
First Prev 2 of 2
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
