  • 1994 - 1995 Specific Tech
LCA Install
  • Thread starter Thread starter Stanger007
  • Start date Start date Dec 16, 2006
Stanger007
2,015
Baton Rouge, LA
Dec 16, 2006
  • Dec 16, 2006
Had a great day working on the cars today - put on my lower control arms (D&D Motorsports econo box) and boy was that an easy job thanks to Sam (sage2k) helping out.
The arms themselves went on with no problems - had a bit of a time getting the swaybar of all things put back on right and getting the parking brake and abs bracket on there too.
Ended up reversing the stock clips that the sway bar bolts onto and using a grade 8 nut and bolt for the rear holes of the swaybar to mount the bracket (after a slight modification) back on. Came out looking factory.
After that we installed an EGR block plate (EGR has been turned off in the EEC for a while now). The Mach 1 even got some love today... I changed the oil and took her for a spin.
The control arms seem to force the tires to the ground and keep it from moving side to side. It's hard to burn out on the Nittos now.
After that we tackled some mods on Sam's ride - I'll let him post on those.
Wes
EDIT: Going to the track tomorrow... we'll see how much the UCA/LCAs really help.
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Dec 16, 2006
  • Dec 16, 2006
You need to take me for a spin in the Mach 1 one day.
Stanger007
2,015
Baton Rouge, LA
Dec 16, 2006
  • Dec 16, 2006
I don't know if you can handle that level of old schooledness!
No school like the old school!
Wes
The Green GT
1,269
Louisiana
Dec 16, 2006
  • Dec 16, 2006
Have you ever brought it to the track?
Stanger007
2,015
Baton Rouge, LA
Dec 16, 2006
  • Dec 16, 2006
Nooo... it's old and slow. It probably puts down high 15s if I had to guess.
sage2k
645
Baton Rouge, LA
Dec 17, 2006
  • Dec 17, 2006
man i had a great day workin on the cars
mods went on easy, no headaches, fun experience
the tweecer is awesome
just the shift retard and idle increase was worth it
I will have more time to play with it later
C
cobra29svt
22
va
Dec 17, 2006
  • Dec 17, 2006
i'd love to put some upper and lower control arms on my car but im afraid it will break my t5 if it doesnt spin.
Stanger007
2,015
Baton Rouge, LA
Dec 17, 2006
  • Dec 17, 2006
Well track results are in - I ended up cutting about the same 60fts as I did a couple weeks ago. Time were about the same - 14.094, 14.193, 14.127 and 14.149 about 0.05-0.1 slower because of the air? It was 55deg last weekend with low humidity, upper 70s today with some humidity. MPHs were all between 95.46 and 95.88
I still don't think I'm heating my Nittos up enough... hard to get a decent burnout w/ the stall and my lack of power.
60's were 1.938, 1.981, 1.941 and 2.003 (tried launching about 1,500rpm into the stall).
The control arms threw off my butt-o-meter so I'm not sure how much I was spinning.
Next time out I'll have to play with the burnout a bit more... only got four passes in today - had a lot of cars leaking fluid on the track.
Wes
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
C
AOD wont go into park
  • chris1993
  • Mar 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2024
Silverfoxx
