I went to change my rear coil springs tonight so I put the car on stands, buzzed off the sway bar, put a jack under the LCA and took the nut off. The problem is I cant get the bolt to come out. It was frozen so tight my Impact Gun didnt work until after several tries. It broke loose, but all the bolt does is spins, it will not back out. Anyone had similar problems, and how did you get the bolt out? Also if anyone has an alternate method to remove the rear spring other than dropping down the control arm, I would appreciate it!
