LCA/UCA Write up
remove the old ones and put the new ones in :shrug:
ive done lowers but never messed with the uppers
for the lowers you need to support the rear from someplace other then the axle
place a jack under the pumpkin and jack it up a little
remove the sway bar and unbolt the shocks
then you can lower the axle and should be able to remove the springs
then you can remove the LCA's
uppers.. :shrug:
I agree that Maximum Motorsports has great instructions available for printing right from their site, I don't like their recommendation on spring removal........it's a little, shall we say..........dangersous:nono: I would suggest using an external spring collapse tool and an air gun..........it's a much safer way to get springs in and out.
I think I got mine at Sears.
Uppers are a piece of cake once the springs are out......just four bolts and viola'.
If you are already lowered, you really dont need a spring compressor, just unbolt the quad shock and the strut and then push down on the axle while pulling the spring out. It was a little hard getting the stocker out, but its a piece of cake with my c springs.
