Leaky Breather
  • Thread starter Thread starter DKeen
  • Start date Start date Mar 14, 2006
DKeen
43
  • Mar 14, 2006
I have a carb'd 351w in my fox, it came with it hen I purchased the car. I've noticed that the breather spits a decent amount of oil while I drive the car, enough that it gets on things and burns off, and just makes a mess in general.
The car seems to have a pvc system, so could I use a closed crankcase cap? or does my car need a breather?
Thanks, Dan
HISSIN50
34
129
Mar 14, 2006
  • Mar 14, 2006
If you choose to keep the breather, you can switch to a closed version, which has a discharge tube. You can route it conveniently to someplace where it can dump (into a can, etc).
Good luck.
DKeen
43
  • Mar 14, 2006
ahh, thats a good idea. thanks
with a closed breather into a can, will it still be a breathable crankcase though? or will the whole can thing pressurize it?
HISSIN50
34
129
Mar 14, 2006
  • Mar 14, 2006
Oh no man, it's not a pressurized (sealed) system. The can is open to atmosphere - it just catches oil out of the discharge tube (You could vent it to the ground, so long as it is done in a way so as to not create a safety/traction issue).
Ford sells a nice lookin breather (Tim - 18Mustangs, has posted a link to it before. I never used that particular model and cant find his link).
Good luck.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Mar 14, 2006
  • Mar 14, 2006
Buy some baffles (Moroso makes a decent kit thats cheap and works),they stoped my oil leaks when I had the breathers.
DKeen
43
  • Mar 15, 2006
I see, I'll have to try one of these ideas, it's just starting to get annoying always having oil burning off of my headers, etc.
Oh yeah, is this a really bad sign that I'm getting so much oil out of my breather?
HISSIN50
34
129
Mar 15, 2006
  • Mar 15, 2006
Dan, if you dont have baffles (like BO suggested), that can misrepresent how much blowby there is.
In my experience having breathers make a mess is not unusual with low tension rings. It's one reason the show cars guys generally do something else (run a PCV, run closed breathers, a catchcan, etc etc).
Good luck.
DKeen
43
  • Mar 15, 2006
I have a feeling my rings are probably getting pretty tired. I bought the car with this engine in it, so I don't know everything in/about it. It makes diagnosing things tough. Thanks for the info again.
HISSIN50
34
129
Mar 15, 2006
  • Mar 15, 2006
A dry vs wet compression (or leakdown) test can tell ya how the ring seal might be doing.
Good luck Dan.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 15, 2006
#10
  • Mar 15, 2006
  • #10
Dan - As rings tire and blow-by increases, more oil will show up through the crankcase ventilation 'system' -- whether it's a close pcv system or an open breather as you have.
How does the current pcv set up work? Is it connected to manifold vacuum, or into the air cleaner? Carb or efi? Does the pcv valve pull from the valve cover or rear of the intake?
If vacuum is pulling on the pcv valve to ventilate the crankcase, then you need a means of make up air for the crankcase so that you won't pull a vacuum on the crankcase. That's the role your breather is performing now. But if you're actually losing a good amount of oil out the breather -- then it sounds like there is more blow by than the pcv valve can handle. And that points to either a clogged pcv system, or a tired engine. If it's a tired engine --- of course the catch can approach is just treating the symtom, not the illness.
DKeen
43
#11
  • Mar 15, 2006
  • #11
I'm a little more noobish than I wish I was, but I believe that the current pcv setup pulls from the valve cover to the manifold. Its a carb'd car. I have a feeling the engine is a bit tired, although it pulls like a bat out of hell.
I plan to buy a 408 shortblock sometime in the next few years, and I only drive the car in the summer months, so I guess I'm just trying to deal with it temporarily.
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
