Leaky Breather
  • Thread starter Thread starter DocG
  • Start date Start date Oct 6, 2008
First Prev 2 of 2
DocG
5th graders > me. They're not bant
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Oct 8, 2008
#21
  • Oct 8, 2008
  • #21
strtrcr50 said:
Under full throttle/hard acceleration/high rpms, there is very little/no vaccuum. However, those rockers are throwing a lot of oil.
It's not on your cold air intake. If you look at your throttle body, you'll see a capped vaccuum port on top. That's where it goes. Ideally, you would put on a set of valve covers designed for a fuel injected motor which will have the baffle and the filler tube and vac port. However, I forget which rockers you have and they may not clear the baffle.
Its raining today....its stopped but roads are wet so I can't really take a test drive to see if the new breather has helped the leak. It doesn't help that the hole for it is right on top of a rocker!
I picked up another breather....a closed one with a port on it. I'm gonna try it on there with a vac hose going to the spot you indicated and see if it makes any differences.
Technically, if anything it should run better having the air return to the system rather than the environment. Also have the stuff to add an oil separator inline with the PCV line....and grabbed a new PCV while I was at it.
Not sure what lifters are on it....might have some specs on them somewhere in my files.
HISSIN50
34
129
Oct 8, 2008
#22
  • Oct 8, 2008
  • #22
The current issue is kinda like having a bad cut and no matter what brand of band-aid you use, it gets soaked through in a few minutes. It's not the band-aids' fault ; getting some stitches would be the solution.
I would figure out a way of having a baffle and the breather should be a lot more effective and less messy.
strtrcr50
Previously from Dirty Jerzey exit 7a
Oct 8, 2008
#23
  • Oct 8, 2008
  • #23
I don't know what you mean by a closed breather but if it can pull in outside air, you don't want to hook up that vac hose. Then you'll have a rather big vac leak right in front of the throttle body butterfly. The only way to do it right is to switch to an efi valve cover with the fill tube and baffle. Or just remove the pcv system and run breathers in both valve covers.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Oct 8, 2008
#24
  • Oct 8, 2008
  • #24
Ok....right now I have the "stock" PCV setup running.
I have an open breather (has vents in the breather itself) running which is tight and not sloppy like the old one.
So far, no oil pushing back up out the breather. I might run it like this and see how she does. Dunno if the vacuum will get messed up by having this breather in the valve or not. This breather has a built in "baffle" and at least doesn't splash from the rocker as easy.
When I say closed breather...I guess breather is a bad term, but it has no access to outside air.
strtrcr50
Oct 8, 2008
#25
  • Oct 8, 2008
  • #25
You mean a sealed cap? Can you post a picture?
The eec will try to adapt for the vaccuum leak. Yours sounds like it's within the range it can adapt for since its not surging.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Oct 9, 2008
#26
  • Oct 9, 2008
  • #26
This is what I mean by closed vs. open
open
closed
With the closed, I would run the line to the air inlet before the TB fuel blades. I would make sure the breather had some sort of baffling built in it along with a separator inline to make sure oil isn't getting through too badly. This would at least close up the system I'd think.
strtrcr50
Oct 9, 2008
#27
  • Oct 9, 2008
  • #27
That looks like it should work to restore you back to a functioning pcv system like the factory designed it.
DocG
Sep 25, 2005
8,297
1,358
194
Cincinnati area
Oct 9, 2008
#28
  • Oct 9, 2008
  • #28
Something like that seems like it would have enough baffle to stop large amounts of oil from coming up through it...add a separator and I should be golden.
First Prev 2 of 2
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
Engine No start issue AGAIN!
  • ucnhtmenow1
  • Sep 1, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 11, 2024
89ripper
C
Anybody recognize this car?
  • ctandc
  • Jun 14, 2023
  • The Welcome Wagon
3K
The Welcome Wagon Apr 27, 2025
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
