Lean at idle
Silvers
51
See my signature, now add a simple novi 1000 kit. The car idles fine till about 5 minutes after reaching normal operating temp, then my air/fuel gauge goes off the scale lean and stays there almost making the car go dead. What could cause this?
My air/fuel gauge gets its info from the O2 sensor and it seems to be working fine. The car runs great when you bypass the supercharger by putting the old cold air intake back on.
You may have inmetered air getting in.
You would think so by the way it tries to go dead but i'm sure its sealed up good. The way it runs fine for 10 minutes then all of a sudden it chokes down like a switch has been thrown seems to point to a sensor, but which one, and why doesn't it do it without the novi hooked up?
No, just a gauge that attaches to the signal wire of the O2 sensor. I dont know if I trust it because the car acts like it is flooding. (choking down, gas fumes filling the shop) The way it hits all of a sudden im leaning towards the coolant temp sensor, air temp sensor or turbulance in the MAF. Im even gonna try a friends computer this weekend.
The A/F gauges that use the O2 sensor signal will jump all over the place. The reason is that the O2 sensors "switch" between
.2 volt lean and .6 volt rich with a curve that looks like the drop off a high cliff. The curve is almost straight up and down, so the
voltage shoots from .2 to .6 and back down . again 2 or more times a second at cruse. You won't get much useful information
except when the mixture is extremely lean or extremely rich, there is no middle ground.
In other words, it is a pretty light show, but useless for tuning or diagnostics.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Update
I cant believe it myself but i changed my air filter from the cone shaped one they sent with the kit back to my oval shaped K&N and it completely fixed all the problems. Air voulume, turbulance, who knows?
