  • 1994 - 1995 Specific Tech
LEAN PROBLEMS...need knowledge!!!
  • Thread starter Thread starter xkuntrycowboyx
  • Start date Start date Dec 15, 2005
xkuntrycowboyx
281
Marion, Indiana
Dec 15, 2005
  • Dec 15, 2005
NEED REAL HELP HERE!
here is a thread a lil about what i've already explained, mainly me and grady
http://forums.stangnet.com/showthread.php?t=601806
ne ways here goes again!
bought car not quite runnin right when you kick it down, around mid throttle, then at like 4-4500 it takes off like a dirtbike powerband! Really noticable in gettin up.
gave it a tune up
oil change
new plugs, wires, cap, rotor (yes all wires on right and plugs gapped right)
set timing
new belt
cleaned k&n (didn't over oil)
sprayed cleaned maf with electronic contact cleaner
replaced AIT
scan comp and get (lean at mid throttle code)
....any help???
skylovia
66
  • Dec 15, 2005
Are you getting a really loud buzzing from your fuel pump? Because i was having a similar problem with running lean at mid throttle. Turns out i had a bad fuel pump, i replaced it and havent had a problem since.
xkuntrycowboyx
281
Marion, Indiana
Dec 15, 2005
  • Dec 15, 2005
i should add... it's in that other thread i posted
also changed the fuel filter 2x's
and while i was messin with fuel, put in a 225 walbro pump..
..thanks tho
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
